15 years agoHow to read from a onchip memory
Hello i want to read data from some adress at the onchip memory, i can do it with IORD and IOWR using altera HAL functions. However those functions are not available for me inside the linux
15 years agoDevice driver to acess on chip memory as a char device (must be made inside linux2.6/arch/nios2/driver)
# include <linux/fs.h># include <linux/sched.h># include <linux/errno.h># include <linux/types.h># include <linux/cdev.h># include <linux/kernel.h># include <linux/module.h># include <asm/current.h># include <asm/segment.h># include <asm/uaccess.h># include <asm/io.h>
# define DRIVER_NAME "shmem"
# define SHARED_MEM_BASE 0x800# define SHARED_MEM_SPAN 2048
typedef struct {
int32_t mutex;
int32_t reset;
} mutex_t;
typedef struct {
mutex_t *mutex;
unsigned char *buffer;
} shmem_t;
static shmem_t shmem;
int shmem_open(struct inode *inode,struct file *filep)
return 0;
int shmem_release(struct inode *inode, struct file *filep)
return 0;
ssize_t shmem_read(struct file *filep ,char *buff, size_t count, loff_t *offp)
int retval;
printk(KERN_INFO "read, count %i, off %i\n", count, *offp);
if (*offp >= SHARED_MEM_SPAN) {
return 0;
if (count > (SHARED_MEM_SPAN - *offp)) {
count = (SHARED_MEM_SPAN - *offp);
retval = copy_to_user(buff, (shmem.buffer+*offp), count);
if (retval != 0) {
printk(KERN_ERR "Kernel to userspace copy failed!\n" );
return retval;
*offp += count;
return count;
ssize_t shmem_write(struct file *filep,const char *buff,size_t count,loff_t *offp )
int retval;
return -ENOSPC;
retval = copy_from_user((shmem.buffer+*offp), buff, count);
if (retval != 0) {
return retval;
*offp += count;
return count;
struct file_operations shmem_fops={
open: shmem_open,
read: shmem_read,
write: shmem_write,
release:shmem_release,
static int shmem_init(void) {
printk(KERN_INFO "shmem device driver init\n");
if(register_chrdev(222,DRIVER_NAME, &shmem_fops)){
printk(KERN_ERR "failed to register\n");
goto chrdev_error;
shmem.mutex = (mutex_t *)ioremap(MUTEX_BASE, MUTEX_SPAN);
if (shmem.mutex == NULL) {
printk(KERN_ERR "failed to map mutex\n");
goto mutex_error;
printk(KERN_INFO "mutex %p\n", shmem.mutex);
shmem.buffer = (unsigned char *)ioremap(SHARED_MEM_BASE, SHARED_MEM_SPAN);
if (shmem.buffer == NULL) {
printk(KERN_ERR "failed to map shared memory\n");
goto buffer_error;
printk(KERN_INFO "shmem %p\n", shmem.buffer);
printk(KERN_INFO "shmem: mutex.reset %02x\n", shmem.mutex->reset);
return 0;
buffer_error:
iounmap(shmem.mutex);
mutex_error:
unregister_chrdev(222, DRIVER_NAME);
chrdev_error:
return -ENODEV;
static void shmem_cleanup(void)
printk(KERN_INFO "shmem device driver unregister.\n");
iounmap(shmem.buffer);
return;
module_init(shmem_init);
module_exit(shmem_cleanup);
A program in user land (uclinuxdist/user/program) to read 32 bits per read # include <unistd.h># include <fcntl.h># include <sys/mman.h>
int main()
int fd = 0;
int value = 0;
int bytes = 0;
fd = open("/dev/mutex", O_RDWR);
if (fd == NULL)
printf("Erro abrindo mutex\n");
return 1;
bytes = read(fd, &value, sizeof(value));
if (bytes < 0)
printf("Error lendo\n");
return 1;
printf("Valor lido: %x\n", value);
if (bytes < 0)
return 1;
lseek(fd, 0, SEEK_SET);
if (bytes < 0)
return 1;
close(fd);
return 0;
