19 years agoHow to read flash using nios2-flash-programmer?
I'm trying to read flash using nios2-flash-programmer. The target is a Cyclone-II based board with a CFI flash. Following the example in the users guide, I've tried this: $ ./nios2-flash-p...
19 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- nios2-configure-sof should be a snap to use... It will even browse your CWD for a SOF if you don't specify any arguments.[/b] --- Quote End --- No joy.$ ./nios2-configure-sof dm_1port.sof
Searching for SOF file:
in .
dm_1port.sof
Internal Error: Sub-system: DEV, File: /quartus/ddb/dev/dev_family_info_mgr_body.cpp, Line: 2005
Failed reading FGEN-generated ASCII family info data /home/grante/h/dev_part_manager_auto.part
Stack Trace:
0x373A : ERR_STACKWALKER::get_stack_trace(ERR_STACKWALKER::NEXT_INSTRUCTION**, int, int, void*) + 0x2C (ccl_err)
0x4DC6E : MSG_INTERNAL_ERROR::report(char const*, char const*, char const*, int) + 0xBE (ccl_msg)
0x1725D3 : DEV_FAMILY_INFO_MGR_BODY::read_default_family_data() + 0x21B (ddb_dev)
0x16FC2E : DEV_FAMILY_INFO_MGR_BODY::load_data_from_pdb(DEV_FAMILY_ENUM, DEV_FAMILY_INFO_MGR_BODY::DEV_FAMILY_DATA_TYPE, FIO_PATH const*) + 0x5AA (ddb_dev)
0x16C7B7 : DEV_FAMILY_INFO_MGR_BODY::get_desc_of(DEV_FAMILY_ENUM) + 0xA5 (ddb_dev)
0x11BE47 : DEV_FAMILY_MANAGER::test_trait_of(DEV_FAMILY_ENUM, DEV_FAMILY_TRAIT_ENUM) const + 0x223 (ddb_dev)
0xA0307 : PGMIO_DEVICE_MANAGER::pgmio_process_parts_file(FIO_PATH, bool) + 0x973 (pgm_pgmio)
0xA2277 : PGMIO_DEVICE_MANAGER::PGMIO_DEVICE_MANAGER() + 0x42D (pgm_pgmio)
0x9DA10 : PGMIO_DEVICE_MANAGER::get_device_mgr() + 0x66 (pgm_pgmio)
0x9CEBC : PGM_DEVICE_INDEX::lookup_device(_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> > const&) + 0x36 (pgm_pgmio)
0x109EF : QPGM_FRAMEWORK::create_chain() + 0x239 (quartus_pgm)
0x11B74 : QPGM_FRAMEWORK::process_operation(_Dinkum_std::basic_string<char, _Dinkum_std::char_traits<char>, MEM_STL_ALLOCATOR<char> >*) + 0x806 (quartus_pgm)
0xDB0A : QPGM_FRAMEWORK::post_check_arguments() + 0x1A4 (quartus_pgm)
0x1C563 : (comp_qexe)
0x27DCE : qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x26 (comp_qexe)
0x136E2 : qpgm_main(int, char const**) + 0x56 (quartus_pgm)
0x3B3F1 : msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xB7 (ccl_msg)
0x1372A : main + 0x40 (quartus_pgm)
0x15896 : __libc_start_main + 0xE6 (c.so.6)
0xA1E1 : __gxx_personality_v0 + 0x81 (quartus_pgm)
End-trace
