19 years agoHow to read flash using nios2-flash-programmer?
I'm trying to read flash using nios2-flash-programmer. The target is a Cyclone-II based board with a CFI flash. Following the example in the users guide, I've tried this: $ ./nios2-flash-p...
19 years ago --- Quote Start --- originally posted by karel van haver@Dec 4 2006, 02:12 AM before you can load your application into the flash --- Quote End --- It's not my application I'm concerned about, it's the .flash file with the FPGA configuration data. <div class='quotetop'>QUOTE </div> --- Quote Start --- you indeed have configure the FPGA first. You can do this easily in your QUARTUS 2 software off course.[/b] --- Quote End --- Just to be clear, are you saying The nios2_flash_programmer doesn't know how to configure the FPGA? So getting the FPGA configuration .flash file into CFI is a two step process that requires QUARTUS and nios2_flash_programmer?
