19 years agoHow to read flash using nios2-flash-programmer?
I'm trying to read flash using nios2-flash-programmer. The target is a Cyclone-II based board with a CFI flash. Following the example in the users guide, I've tried this: $ ./nios2-flash-p...
19 years ago --- Quote Start --- originally posted by karel van haver@Dec 4 2006, 02:12 AM before you can load your application into the flash, you indeed have configure the fpga first. you can do this easily in your quartus 2 software off course. --- Quote End --- I don't have QUARTUS 2 software. Isn't there a way to configure the FPGA via command line using something from the NIOS2 development toools?
