19 years agoHow to read flash using nios2-flash-programmer?
I'm trying to read flash using nios2-flash-programmer. The target is a Cyclone-II based board with a CFI flash. Following the example in the users guide, I've tried this: $ ./nios2-flash-p...
19 years agoHey
Before you can load your application into the flash, you indeed have configure the FPGA first. You can do this easily in your QUARTUS 2 software off course. QUARTUS 2 >> TOOLS >> Programmer Just scan for devices and load your FPGA .sof file into your corresponding FPGA. Now, a volatile FPGA configuration is loaded into your FPGA by JTAG. After power down this configration get lost. So, therefore you have to store your fpga data into a non-volatile memory such as your CFI flash. So, after you have loaded the .sof file you will be able to use the nios2-flash-programmer command. Regards Karel
