15 years agoHow to re-generate "time-limited" *.sof file of Nios design?
I have a Nios license but I want to generate a "time-limited" sof file for my Nios design. I had tried to remove feature 6AF8_00A2 and 6AF7_00A2 in my license file, BUT it doesn't work... ...
15 years agoThanks for your Hint!
I forget to run SOPC Builder to re-generate Nios system after I remove feature 6AF7_00A2 and 6AF8_00A2. Now, it takes effect! The reason to make a time-limited sof is that I want someone to do just "evaluation" with a PC, i.e., someone CAN'T free run on stand-alone FPGA board. --- Quote Start --- Hi, Why generating a time-limited sof file ? did you close Quartus, NIOS and restart them 20 seconds later (because of windows prefetch, cache ... ) ? --- Quote End ---
