14 years agoHow to provide different clock for PHY Device
My board DE2-115 My PHY Device:88E1111 My project is about simple socket server.Now I can send words or command via Telnet or Ping, when I use a router(100Mbps). But, when I directly connec...
14 years ago --- Quote Start --- DO NOT TOUCH CONTENTS OF THAT FILE. Usually, it is already read-only. You have to generate 125MHz Yourself and supply that clock to the mii/gmii mux core. It's simple to read comments and undestand how it work. Do that instead of asking in forum. Ask here things that You can't get running, but not things, that You don't understand. --- Quote End --- Hi Socrates,I have changed the output clock of PLL to 125Mhz, provided for MAC. But 1000Mbps is still failed. When you do something about ethernet, what did you do to enable 10Mbps and 100Mbps and 1000Mbps. You switch them by changing what? Hope for your reply.
