How to program ep4ce6e22c8n using FT4232HQ in Ubuntu 22.04 machine?
We can't help if you have issue with FTDI chip because we don't have resource to support other company device.
By default if you are using USB Blaster II programming cable provided by Intel, you just connect the programming cable to Cyclone IV device and it will be able to configure the FPGA via Quartus programmer tool.
regards,
Farabi
Hi Farabi,
I can understand.
The nearest solution recommended by FTDI was to follow the schematic https://ftdichip.com/wp-content/uploads/2020/12/Morph-IC-II-Schematic-Prints.pdf of the Morph II system and make a similar connection of the FT-H devices to an FPGA/Cyclone IV device and with the source code available you can create your own program to communicate with the FPGA.
For sure the https://ftdichip.com/wp-content/uploads/2020/08/AN_173_Establishing_FT1248_Communications_using_a_Morph-IC-II.pdf solution need to replaced with the Cyclone IV device. So here I need your help where your team can provide a Verilog based program/solution to me to move ahead.
LMSM
