21 years agoHow to program a flash using a normal programmer
We have a project of Nios I, my question is when we produce this board, we should program the flash using a normal programmer before it is put on PCB. We use srec2flash and hex2flash to generate ...
21 years agoHi hjia,
> the .flash file has a boot command attached at the upside of .srec > Also we have FPGA configure contents in this flash. Ok, I understand ... sounds like it's time to code up a utility ;-) Regards, --Scott
