21 years agoHow to program a flash using a normal programmer
We have a project of Nios I, my question is when we produce this board, we should program the flash using a normal programmer before it is put on PCB. We use srec2flash and hex2flash to generate ...
21 years ago --- Quote Start --- originally posted by smcnutt@Jun 20 2005, 06:05 AM hi hjia,
> we use srec2flash and hex2flash to generate the .flash file
> but what i mean is to program the flash thru the stand-alone universal
> device programmer for mass production.
> this programmer is a hardware as altera apu.
> .flash file is not a normal hexadecimal file which can be programmed by
> a programmer.
what format do you require? most programmers support srec ... and
you already have that format.
> then how can i get a hex file from a .flash file for programming?
are you referring to intel hex format?
regards,
--scott --- Quote End --- Hi Scott, Can we only program the SREC to flash? I know that the .flash file has a boot command attached at the upside of .srec, which cannot be used by a programmer. If we only download .srec to flash, can Nios run at power up automatically? Also we have FPGA configure contents in this flash. SOF can be converted to HEX. Regards, Hjia
