21 years agoHow to program a flash using a normal programmer
We have a project of Nios I, my question is when we produce this board, we should program the flash using a normal programmer before it is put on PCB. We use srec2flash and hex2flash to generate ...
21 years agohjia, One idea, since you can program your plug-in flash using the uart, you could do that first and then remove the chip and read its contents in your universal programmer. You could then save the file in any format supported by the programmer.
