21 years agoHow to program a flash using a normal programmer
We have a project of Nios I, my question is when we produce this board, we should program the flash using a normal programmer before it is put on PCB. We use srec2flash and hex2flash to generate ...
21 years agoHi hjia,
> We use srec2flash and hex2flash to generate the .flash file > But what I mean is to program the flash thru the Stand-alone Universal > Device Programmer for mass production. > This programmer is a hardware as Altera APU. > .flash file is not a normal hexadecimal file which can be programmed by > a programmer. What format do you require? Most programmers support SREC ... and you already have that format. > Then how can I get a hex file from a .flash file for programming? Are you referring to intel hex format? Regards, --Scott
