21 years agoHow to program a flash using a normal programmer
We have a project of Nios I, my question is when we produce this board, we should program the flash using a normal programmer before it is put on PCB. We use srec2flash and hex2flash to generate ...
21 years agoYes, we are now using UART to program flash.
But what I mean is to program the flash thru the Stand-alone Universal Device Programmer for mass production. This programmer is a hardware as Altera APU. .flash file is not a normal hexadecimal file which can be programmed by a programmer. Then how can I get a hex file from a .flash file for programming? Thanks! hjia
