21 years agoHow to porting u-boot to my own board?
Hello, everyone I want to use u-boot on my board. I have two questions. 1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file. I use ...
20 years agoHi Scott,
It make me headache. My Flash progrmmer (Microtronix official Providing) can not work under Nios SDK Shell. But it works fine in Nios IDE. I re-generate my flash-programmer design, but the same. The infomation under Nios SDK Shell is (I copy .sof to u-boot directory) <div class='quotetop'>QUOTE </div> --- Quote Start --- > $ nios2-flash-programmer --base=0x0 --input=u-boot.flash --sof=mtx_nios_dev_board_cyclone_1c20.sof nios2-flash-programmer: Launching Quartus Programmer to download: mtx_nios_dev_board_cyclone_1c20.sof (here download to my FPGA) Send <64> failed. Unable to synchronize with target. ......nios2-flash-programmer: Error opening target hardware[/b] --- Quote End --- OR <div class='quotetop'>QUOTE </div> --- Quote Start --- ......nios2-flash-programmer: Error opening target hardware ......nios2-flash-programmer: Unable to open flash device after successfully communicating with target.[/b] --- Quote End --- Is there any difference between nios2-flash-programmer in Nios SDK Shell and Flash Programming in Nios IDE? LiangYi
