21 years agoHow to porting u-boot to my own board?
Hello, everyone I want to use u-boot on my board. I have two questions. 1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file. I use ...
20 years agoHi LiangYi,
> You said I can use flash.c. So, I browse flash.c(include /common/flash.c). I found AMDLV065D.c > just have both parts of two flash.c files. So, I think I can change AMDLV065D.c to my use. I was referring to the flash.c files found in most board-specific trees. Most of the supported boards (see the boards directory tree) contain a file named "flash.c" -- this is a common convention in u-boot. The boards that show support for the AM29DL323 are for example, RPXClassic, RPXlite_dw, and some of the esd boards (esd/common). Those trees will probably have the code you can use. > use NIOS_IDE Flash Programmer to download u-boot to my flash. After that I run ># nios2-terminal > Nothing happen, I do know why? You probably still have the flash programmer design loaded. Try reloading your application sof. > Communication port must be specified. > Use openport <port> to configure the communication port This is probably your problem ;-) Regards, --Scott
