21 years agoHow to porting u-boot to my own board?
Hello, everyone I want to use u-boot on my board. I have two questions. 1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file. I use ...
20 years agoHi Scott,
I am in trouble now. 1. My u-boot flash driver You said I can use flash.c. So, I browse flash.c(include /common/flash.c). I found AMDLV065D.c just have both parts of two flash.c files. So, I think I can change AMDLV065D.c to my use. I change CFG_MAX_FLASH_SECT and CFG_MAX_FLASH_BANKS(in board.h), change flash_id = FLASH_MAN_AMD + FLASH_AMDL323B. Is it right? 2. In order to Programming U-Boot into Flash, I add 1M sram. But, when do as USING.TXT, it appears <div class='quotetop'>QUOTE </div> --- Quote Start --- System Analyzer for Nios® II Processor Serial number Version 1.9.4 build 0 Copyright © 1998-2004 First Silicon Solutions, Inc. Communication port must be specified. Use openport <port> to configure the communication port cd d:/My_Project/MtxCyclone_uBoot/BootLoader/u-boot-src/u-boot 1> halt Communication has not been established with remote unit. 2> load bin 0x00600000 u-boot.bin Communication has not been established with remote unit. 3>[/b] --- Quote End --- Why? 3. I use NIOS_IDE Flash Programmer to download u-boot to my flash. After that I run # nios2-terminal Nothing happen, I do know why? Thanks, LiangYi
