21 years agoHow to porting u-boot to my own board?
Hello, everyone I want to use u-boot on my board. I have two questions. 1. Before I use u-boot on my board, I just try to compile u-boot first. So, I follow the readme file. I use ...
21 years agoHello Scott,
I modify some code according to my board and U-boot runs on my board. It runs in sdram. <div class='quotetop'>QUOTE </div> --- Quote Start --- U-Boot 1.1.3 (Sep 14 2005 - 16:46:34) CPU?nbsp; : Nios-II SYSID : 3ef94735, Wed Sep 14 08:39:42 2005 BOARD : Microtronix MCK-1C20 *** Warning - bad CRC, using default environment ==>[/b] --- Quote End --- But I still have some questions. 1. When I change the TEXT_BASE in config.mk, u-boot can not be made. Can you tell me detailed about TEXT_BASE, and how to set it? 2. First, I creat a new directory to store the new platform. make xxxx_config --------OK make ---------error <div class='quotetop'>QUOTE </div> --- Quote Start --- make -C 'dirname board/microtronix/mtxkit1c20/libmtxkit1c20.a' make[1]: Entering directory '/cygdrive/....../u-boot/board/microtronix/mtxkit1c20' make[1]:*** No rule to make target 'mtxkit1c20.c', needed by '.depend'. Stop. ...... make: *** [board/microtronix/mtxkit1c20/libmtxkit1c20.a] Error 2[/b] --- Quote End --- But when I put the platform under altera directory, u-boot is made OK. Why? 3. I run saveenv and re-run, but the warning still appear. Why? Thank you, LiangYi
