20 years agohow to port uclinux on custom board
Dear all,
now i want to port uclinux on my custom borad , there are 8900,ep1c6,sdram,flash(8m),i download the UCLINUX1.4 and do accord to the document ,but but no platform i can choise because i use my board, Can you help me! thanks!2 Replies
Hi nwpu_zhf2004
As far as I understand, the Platforms that one can select from is there to make it easy for the guys to start up with their devkits. You can select any platform that is close to your design and enable or disable modules and functions you want or dont want. For new or unsupported hardware you placed in your design, you will have to create your own drivers(or edit existing ones is easier) and probably recompile/build your kernel with these drivers. Good luck Rual - Altera_Forum
hi rual,
i will try it ,thanks! best regards! nwpu_zhf2004
