21 years agohow to port nios2 to stratix dsp s80 board?
i want to know if it's possible? thank u!
21 years agoHello ffone13,
Of course it is possible to use the Nios II with your DSP EP1S80 board. There are several ways to bring your board to work with the Nios II. 1. Take an existing reference and change all the stuff which is different to your board like FPGA, SDRAM, Flash, Pin assignments, … 2. Setup a complete new system as it is described in the “Nios II Hardware Development Tutorial” Both ways need some time and work but as there is no reference design you have to do this by yourself. Good luck, niosIIuser
