20 years agohow to modify alt_sys_init()?
hello,everybody,when bulid a project,alt_sys_init() initializes every single device in your system--even ones which your application may not use,how can i to modify alt_sys_init() so as to initial...
20 years agoyes , i have found the readme.txt that gives a example,thank you!wolf,
but i have another question,how can i generate .elf in the nios 2 IDE,i want to downlode a program into the flash that can run at the reset time,i use the flash programmer ,but it must the *.elf file,but i do not know how to generate *.elf in the nios 2 IDE, i have a think that if can run run in the nios2 SDK shell,but in the shell,use" nr ××.c ",the error message is no makefile,have every one tell me how to generate .elf file in the nios 2 IDE and how to compile C.file in the nios2 SDK shell successfully. thank you!
