20 years agoHow to make very compact code
I have some code that gets run whenever the processor is reset and basically reads a register continually, waits for it to be set to '1' and when it is, sets up a DMA (by setting the register...
20 years agoIf you are using the JTAG UART, the driver for the UART requires 4kBytes of memory just for the software buffers.
You could modify the altera_avalon_jtag_uart.h to lower the size of the software buffers, or you could remove the JTAG UART from your design.
