16 years agoHow to make the uclinux boot faster?
Sash command shell (version 1.1.1) /> Uncompressing Linux... Uncompressing Linux... Ok, booting the kernel. [ 0.000000] Linux version 2.6.30 ([email protected]) (gcc version 3. 4...
16 years agoHow do you make vmlinux bootable? It seems that the default boot loader wants to uncompress whatever is in the Flash.
After taking out the initramfs, I created the soft.flash image using the following command: elf2flash --base=0x06000000 --end=0x06ffffff --reset=0x06300000 --input=vmlinux --output=soft.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec Then I wrote soft.flash to Flash. If I try to open the nios2-terminal, there is a partial message: "Uncompres" nothing else after that. I'm using the NEEK board to test this out. Thanks
