13 years agoHow to make initramfs smaller
This is what I get after compilation of kernel nios2-linux/uClinux-dist/images: -rwxrwxr-x. 1 lukasz lukasz 6592577 Jan 29 17:19 linux.initramfs.gz -rw-rw-r--. 1 lukasz lukasz 8903168 Ja...
13 years agoThanks dsl.
This is like you are saying. I have succesfully booted linux MMU on 8MB SDRAM but I needed removed a lot of things from the kernel and app/lib. I needed also check in blackfin options this: Blackfin build options ─> [*] Cull unused ELF shared librariesproblems with kernel aft Unfortunatelly kernel is not useable. I can not even use telnetd(busybox or external) or load any module. So I came back to DE2-70 where I have 32MB SDRAM. I fight there with DM9000 to make it stable because some time driver is loading fine but some time is not. I changed some parameters in sopc builder with avalon bus and I need make more tests to say if it helped.
