20 years agohow to make ftpd work??
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif my board is based on 1c12, i have made a successful zImage according to the steps described in wikinios.jot.com. and i can ...
20 years agoHi,
is there a solution for the "command not understood"-Problem? I get exakt the same message. Thanx Marco --- Quote Start --- originally posted by fbc99@Jun 7 2006, 11:47 PM http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/cool.gifmy board is based on 1c12, i have made a successful zimage according to the steps described in wikinios.jot.com. and i can telnet to my board from pc .
now i want to have a ftp server on my board:
what i have dones is fowllowing:
(1)
when "make menuconfig"
i select "ftpd" in "network application" and select "chroot" in "busybox" and select "adduser , addgroup , passwd" in " tinylogin"
(2)
then :
make clean
make romfs
make
create two empty files in romfs/etc: passwd group
make romfs
make linux image
(3)
then download the zimage to my board.
(4)
add a user in board using "adduser ftptest", but i get "adduser: cannot determine your user name." messge
but it seems that a new user has been added because then content of the file etc/passwd becomes "ftptest:x:500:500::/home/ftptest:/bin/sh"
and the etc/group is: "ftptest:x:500:"
(5) then try to test ftp serve with the "ftptest" username
ftp 192.168.0.202 (192.168.0.202 is my board ip)
then i got the following message:
connected to 192.168.0.202.
220 uclinux ftp server (gnu inetutils 1.4.1) ready.zj2
name (192.168.0.202:none): ftptest
500 'user ftptest': command not understood.
login failed.
ftp>
(6) there are no choices for me instead of "bye"
i have do some more efforts, such as change the ftpd.c , but i have the same result " command not understood"!!
if anyone can tell me what's the problem?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16017)
--- quote end ---
--- Quote End ---
