20 years agohow to make ftpd work?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
my board is based on 1c12, i have made a successful zImage according to the steps described in wikinios.jot.com. and i can telnet to my board from pc . now i want to have a ftp server on my board: what i have dones is fowllowing: (1) when "make menuconfig" i select "ftpd" in "network application" and select "chroot" in "busybox" and select "adduser , addgroup , passwd" in " tinylogin" (2) then : make clean make romfs make create two empty files in romfs/etc: passwd group make romfs make linux image (3) then download the zImage to my board. (4) add a user in board using "adduser ftptest", but i get "adduser: Cannot determine your user name." messge but it seems that a new user has been added because then content of the file etc/passwd becomes "ftptest:x:500:500::/home/ftptest:/bin/sh" and the etc/group is: "ftptest:x:500:" (5) then try to test ftp serve with the "ftptest" username ftp 192.168.0.202 (192.168.0.202 is my board ip) then i got the following message: Connected to 192.168.0.202. 220 uClinux FTP server (GNU inetutils 1.4.1) ready.zj2 Name (192.168.0.202:none): ftptest 500 'USER ftptest': command not understood. Login failed. ftp> (6) there are no choices for me instead of "bye" i have do some more efforts, such as change the ftpd.c , but i have the same result " command not understood"!! if anyone can tell me what's the problem?4 Replies
i have tried to changed some code in user/ftpd/ directory, such as ftpd.c, auth.c,
for example, i do nothing in auth_user() and auth_pass( ) functions in auth.c but just let " return 0 " as the first line of functions. ( of course it let auth_user, auth_pass to be successful!) but i got the same result: "command not understood"! i have given up my effort to cope with ftpd. i think my knowledge of linux programming is not enough to do this work! i have installed ftp server in my WINXP, so i can transfer programs from my notebook computer to my board and then run them. i still longs to have some tips to conquer the ftpd! thanks to it!! - Altera_Forum
The problem may be in ftpcmd.c . The user command is not parsed correctly.
But I didn't have much time to look into it. - Altera_Forum
--- Quote Start --- originally posted by hippo@Jun 10 2006, 08:30 AM the problem may be in ftpcmd.c . the user command is not parsed correctly.but i didn't have much time to look into it.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16083)
--- quote end ---
--- Quote End --- OK, I will try it. ftpcmd.c is much more difficult to read and understand. best regards!!
--- Quote Start --- originally posted by fbc99+jun 11 2006, 08:25 am--><div class='quotetop'>quote (fbc99 @ jun 11 2006, 08:25 am)</div>--- quote start ---
<!--quotebegin-hippo@Jun 10 2006, 08:30 AM the problem may be in ftpcmd.c . the user command is not parsed correctly.
--- quote end ---
--- Quote End --- OK, I will try it. ftpcmd.c is much more difficult to read and understand. best regards!! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16087)</div> [/b] --- Quote End --- It is generated from ftpcmd.y . You may use ftpd in apps of mx140 as in the buildroot guide.
