19 years agoHow to make custom target board?
hi,I'm creating my own target board with the board discription editor.I use quartus2, version 5.1,and Nios2 version 5.1.it seems that mk_target_board can't be used.I just declared the flash...
19 years agoI usually received this message when my processor was not functioning. There may be many reasons for it.
If you already tested a working processor design with the board than, check how you connect reset, some of my designs worked with the reset_n connected to VCC but lately I usualy have to use a timer generating a reset pusle (I am not sure it this timer is realy needed, since at the same time I changed the chip from Cyclone to Cyclone II and changed Quartus to a newer version). If it is the first time you try to start the board than: - check power supply - check if you get the clock (connect a blinking led to a timer connected to the clock) - check the reset signal for the processor - try a processor without an external chips, use internal RAM (this way you know that at least the Altera chip works) - try the full design IzI
