19 years agoHow to make custom target board?
hi,I'm creating my own target board with the board discription editor.I use quartus2, version 5.1,and Nios2 version 5.1.it seems that mk_target_board can't be used.I just declared the flash...
19 years ago --- Quote Start --- originally posted by cicizhang@Nov 22 2006, 12:12 AM thank you two for your reply.i really appreciate.i've made my target board,generated the sopc builder system,compiled the quartus project,and built an easy c project(hello led) ,after that,the .sof file is downloaded successfully.but while i run the project to the hardware,there's a mistake:
Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pausing target processor: FAILED Leaving target processor paused[/b] I've no idea what causes this problem. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19568) --- Quote End --- [/b] --- Quote End --- Can you try USB blaster instead LPT1?
