19 years agoHow to make custom target board?
hi,I'm creating my own target board with the board discription editor.I use quartus2, version 5.1,and Nios2 version 5.1.it seems that mk_target_board can't be used.I just declared the flash...
19 years agoInstructions for creating a board description on a board without specifying a netlist:
1. open SOPC builder for your project 2. File -> New Board Description... 3. in the Netlist tab, select the Device Family 4. in the Flash Memory tab add EPCS and/or CFI Flash, when selecting a name, be careful not t select a name already used by Altera, it may cause problems 5. in the same tab add a hardware image (for EPCS Flash in my case) 6. in the Files tab specify the Board Description Name, again be careful with name repetition 7. the other tabs can be left untouched 8. press Finish 9. select the new board with your design Note: you may have to restart SOPC builder or something like that IzI
