20 years agoHow to make applications run on nios2linux
Hi , How to make applications run on nios2linux by comman mount or ftpd. because the kernel is romfs, I can't mount linux host and windows xp. I can't send files to filesystem by ftpd ei...
20 years agoThe problem should be in library binding. Which Linux distribution did you use?
Do you have sdram on your board? you should run uclinux from it.
