20 years agoHow to make applications run on nios2linux
Hi , How to make applications run on nios2linux by comman mount or ftpd. because the kernel is romfs, I can't mount linux host and windows xp. I can't send files to filesystem by ftpd ei...
20 years ago --- Quote Start --- originally posted by hippo@Mar 10 2006, 09:46 AM good, so you have the buildroot/gcc/uclibc/busybox successed?
use the mininal .config copied from the kernel.config or kernel2.config attached.
only change the console (either serial or jtag). do not change any other setting. change others only after you have a successful boot.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13306)
--- quote end ---
--- Quote End --- Hi hippo. After I did, It likes follow: ~/buildroot/build_nios2/staging_dir/bin has tools . ~/buildroot/toolchain_build_nios2 has binutils-2.15 ,binutils-2.15-build,uClibc etd dirs. It's hard for me to make vmlinux.On sopc builder,I made a "nios2+jtag+onchipram+cfi+ext_flash" system, and get a ptf file.During config the kernel, I did what you said (oad kernel.config and just change the serial console to jtag). But it still can't succeed. The most errors are like :undefined reference to `__udivsi3' undefined reference to `__modsi3' Please give me some advice. is it because ptf file or config problems? I trid many ways , but failed.
