20 years agoHow to make applications run on nios2linux
Hi , How to make applications run on nios2linux by comman mount or ftpd. because the kernel is romfs, I can't mount linux host and windows xp. I can't send files to filesystem by ftpd ei...
20 years agogood, so you have the buildroot/gcc/uclibc/busybox successed?
Use the mininal .config copied from the kernel.config or kernel2.config attached. Only change the console (either serial or jtag). DO NOT change any other setting. Change others only after you have a successful boot.
