20 years agoHow to make applications run on nios2linux
Hi , How to make applications run on nios2linux by comman mount or ftpd. because the kernel is romfs, I can't mount linux host and windows xp. I can't send files to filesystem by ftpd ei...
20 years agoI don't have QQ.
You need two PCs, use the windows XP with quartus 5.1sp1 and nios2 5.1sp1, which is used to compile hardware and download sof/elf/flash. Another Linux PC, (does not need quartus), used to build software, (tools/kernel/apps). Run a samba server (or client) on Linux PC, so that they can share files. The zip files are at the end of post#1 in the thread. You can use the Linux distribution which you are familiar. You should use the latest release of it. And you should have gcc 3.xx .
