12 years agoHow to initialize SD-Card with SPI Command?
Hi, I implemented the Altera SPI Core in my SoPC. Altera provides one access routine "alt_avalon_spi_command()". How exactly can I implement the typical SD-Card Initialization in my Code? Altera S...
12 years agoI was able to solve the problem. But now, when I try to read the MBR. I am only able to read the first 4-5 bytes of MBR. The other bytes are all 0xff.
Could it be due to the speed of the SPI? The SPI speed is 200 KHz. I don't change the speed value at any time. I know that 400 KHz is max speed when initializing the SD Card. After initializing the SD Card, the SPI speed can be set (up to 25 MHz i guess) I don't know what else I can try to solve this problem. I would appreciate your help :)
