16 years agoHow to increase Nios II/s CPU Data Cache
Dear Friends, my nios CPU had instruction cache is 4k byte (default)and data cache is 2k byte(default). I had read data through Ethernet using UDP and my packet size is 1024, as i put my...
16 years agoyou can flush the data cache whenever you want / need too.
have a look at the HAL file alt_cache.h you can increase the cache when you open your quartus project, open the sopc builder and modify the nios cpu core then re-generate the sopc and recompile the fpga. you could also change the nios-s to nios-f if you want at the same time.
