14 years ago
How to improve my ethernet's transfer speed?
My board : DE2-115
SOPCBuilder : DE2_115_WEB_SERVER_RGMII_ENET1
NIOS II software :Simple_Socket_Server(RGMII)
Now I can transfer data to my PC in both 1000Mbps and 100Mbps mode.
But the speed is really low, and 1000Mbps and 100Mbps mode don't have any differences. The speed is about 2.1MB/s.
My codes in simple_socket_server.c are as follows.
I hope that I can get some help to raise the transfer speed.
********************simple_socket_server.c*****************
#include <stdio.h># include <string.h># include <ctype.h>
/* MicroC/OS-II definitions */# include "includes.h"
/* Simple UDP Client definitions */# include "simple_socket_server.h" # include "alt_error_handler.h"
/* Nichestack definitions */# include "ipport.h"# include "tcpport.h"# define MAXDATASIZE 1450
void SSSSimpleSocketServerTask()
int fd_listen;// max_socket
int fd_listen1;
int long bytes_sent;
int long bytes_recv;
int nSendBufSize=SSS_TX_BUF_SIZE;
struct sockaddr_in server_addr;
struct sockaddr_in client_addr;
fd_listen = socket(AF_INET, SOCK_STREAM, 0);
setsockopt(fd_listen,SOL_SOCKET,SO_SNDBUF,(char * )&nSendBufSize,sizeof(int));
if (fd_listen< 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Socket creation failed");
else
printf("Socket created");
server_addr.sin_family = AF_INET;
server_addr.sin_port = htons(SSS_PORT);
server_addr.sin_addr.s_addr = INADDR_ANY;
memset(&(server_addr.sin_zero), '\0', 8);
if ((bind(fd_listen,(struct sockaddr *)&server_addr,sizeof(server_addr))) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Bind failed");
else
printf("Bind is OK\n");
if ((listen(fd_listen,5)) < 0
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Listen failed");
else
printf("Listen is OK\n");
int client_addrlen;
client_addrlen=sizeof(client_addr);
fd_listen1 = accept(fd_listen,(struct sockaddr *)&client_addr,&client_addrlen);
while(1)
if(fd_listen1<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Accept creation failed");
else
printf("accepted connection request\n");
fd_listen = fd_listen1;
break;
printf("Server: Sending some test data to client...\n");
char sendbuf[MAXDATASIZE] = "Bjtuxuxu Love FPGA!";
char recvbuf[200] = "";
while(1)
bytes_sent = send(fd_listen,sendbuf,SSS_BUF_LEN,0);//strlen(sendbuf)
if(bytes_sent<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Send failed");
else
printf("SERVER : Send is OK \n");
printf("SERVER : Bytes sent:%ld.\n",bytes_sent);
bytes_recv = recv(fd_listen,recvbuf,200,0);
if(bytes_recv<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Recv failed");
else
printf("SERVER: recv() is OK.\n");
printf("SERVER: Received data is: \"%s\"\n", recvbuf);
printf("SERVER: Bytes received: %ld.\n", bytes_recv);
return ;
    a good start is to read the AN440 wich describes optimizations (CPU frequency increase, cache, etc...).
    Minimize the number of receive call's by using Bigger TCP packet
    Yeah, I also want to use bigger TCP packet.
    I should change the value of SSS_BUF_LEN or something else.
    Please give me some more advice, thank you!
