21 years agoHow to implement Xvfb?
I would like to know if i can implemente the xvfb in uClinux in and nios plataform.
I've tried to uncompress just like the install said, but the NiosII DSK shell send me a message like this: Program too big to fit in memory I'd apreciate anyone could help... Einar Gonzalez5 Replies
Hi... I don't know what xvfb is, but if it's a user application, then it might help to turn on "Large block allocation" within the kernel.
The option is located at: Processor type and features --> Allow allocating large blocks (> 1MB) of memory re-build, upload, an try your app again... (if it's an app) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif - Altera_Forum
XVFB provides a virtual Xserver that runs without a head or graphics card, so that it is not necessary to have to run a real Xserver.
I'm triying to implemente it to test...but i'm doing it not in the the target, but in the SDK [SOPC Builder]$ Einar - Altera_Forum
I'm not sure I understand... it sounds like you're trying to get it running under Cygwin?
I'm trying to uncompress the Xvfb.tgz, bucause i cant do it when i'm running on the target....
There are plenty of sites out there that provide information about uncompressing .tgz files...
for starters, try: tar -zxf xvfb.tgz The -z means that the archive is compressed -x means extract the files from the archive -f means that the next argument is the filename to work with Good luck!
