20 years agoHow to implement my own bootloader
My system doesn't use CFI Flash but SPI Flash, so I have to creat my own bootloader to read code from SPI Flash to SDRAM. Now, I have implemented a bootloader code which is located in an onchip memory and it can work fine to read data from SPI Flash to SDRAM. But I have a important question: Before reading data from SPI Flash to SDRAM, I should initialize the SPI Flash with my Main Code, but how can I get Main Code??? As I know, NiosII IDE will create *.elf for you, but this file will contain many more redundant code which is for programming CFI Flash. What I need is only the following sections: .exceptions, .rodata, .rwdata and .text Anyone help? Thanks very much!4 Replies
Hi David,
> As I know, NiosII IDE will create *.elf for you, but this file will contain many more > redundant code which is for programming CFI Flash. What I need is only the following > sections: > .exceptions, .rodata, .rwdata and .text Use nios2-elf-objcopy. Regards, --Scott - Altera_Forum
Hi Smcnutt:
I'm not familiar with TCL tools, in fact, I never use them. Could you teach me how to use nios2-elf-objcopy and what will I get? Or, if there is any document related to TCL tools, pls let me know! Thanks very much! - Altera_Forum
objcopy is part of binutils -- use it from a command shell prompt. > Could you teach me how to use nios2-elf-objcopy and what will I get? Try: $ nios2-elf-objcopy --help You can also review documents\gnu-tools\binutils\binutils.html in your nios2 installation directory. Regards, --Scott - Altera_Forum
Dear Scott:
Thanks very much! Everything is OK, now! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif Best regards, David
