16 years agoHow to get SOPC builder to recognize a SRAM controller
Hi, I have a custom SRAM controller in a SOPC system. Nios can access the external SRAM through it with no problem. My question is: how could I make it available as an option for setting the re...
16 years ago --- Quote Start --- In your component tcl file, you need to set the isMemoryDevice option to "true". Look at this post http://www.alteraforum.com/forum/showthread.php?t=24306 --- Quote End --- Hi Ironmoose, Thank you for your advice. But this feature is depricated now in QII 9.1 SP2. I did give it a try anyway and the SOPC builder did recognize the sram controller as one of the option for reset vector and exception vector, but it breaks the NIOS in a way that I can't even run a hello world program. The functional simulation also failed at one of the assertions in the cpu testbench. Since this is depricated, is there a formal way of setting a IP as a memory device? A link to an Altera documentation would be much appreciated. Thanks, Hua
