How to get physical address in Windows
I need to test PCIe DMA suported by Stratix4GX HardIP. In order to perform DMA transactions from PCIe card to System Memory, I need to request Windows to allocate some memory. In additioin, I need to pass the PHYSICAL address to DMA logic so it can generate cycles to system memory. I am using C programming language and not sure how to do that in Windows XP.
Access to physical addresses is reserved to Windows kernel drivers. The Microsoft device driver kit (DDK) has all necessary informations and tools to achieve it.
WinDriver has a function "WD_DMALock"
Jungo WinDriver has the wizard utility, I am curious if that can be utilized to request a block of physical memory. Though I do not have the windriver wizard utility installed yet. I do see the WinDriver under Jungo in device manager.
I will see how I can utilize the WdDma_Lock function - Altera_Forum
Remember that you will either need to have allocated memory that is physically continuous, or allow for physical address discontinuities at page boundaries (assume a 4k page if you don't know the page size).
