16 years agoHow to get Physical Address in uClinux with MMU
Hi~ I am using uClinux with mmu right now. and I want to write a driver for SGDMA(Stream to Memory). I need physical address to set up SGDMA. Is there anyone know about it? Right Now...
16 years agoHi htmin,
How did you boot your board with uClinux? My board is NEEK and I tried the steps in Wiki http://www.nioswiki.com/linux/linux_quick_start with cycloneIII_embedded_evaluation_kit_standard.sof (neek_web_server_mmu.zip) and cycloneIII_3c25_niosII_standard (example/standard)
$ nios2-configure-sof /home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_embedded_evaluation_kit_standard.sof
/opt/altera10.0sp1/quartus/adm/qenv.sh: line 109: warning: setlocale: LC_CTYPE: cannot change locale (en_US): No such file or directory
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag -o p;/home/rgnurrahmat/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_embedded_evaluation_kit_standard.sof
Info: Using programming cable "USB-Blaster "
Info: Using programming file /home/rgnurrahmat/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_embedded_evaluation_kit_standard.sof with checksum 0x00D122FE for device EP3C25F324@1
Info: Started Programmer operation at Thu Sep 16 03:31:39 2010
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020F30DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Thu Sep 16 03:31:41 2010
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 77 megabytes
Info: Processing ended: Thu Sep 16 03:31:41 2010
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:01
~/nios2-linux/uClinux-dist
$ nios2-download -g images/linux.initramfs.gz
Using cable "USB-Blaster ", device 1, instance 0x00
Processor is already paused
Initializing CPU cache (if present)
OK
Downloaded 5283KB in 47.3s (111.6KB/s)
Verified OK
Starting processor at address 0xD0000000
$ nios2-terminal
nios2-terminal: Unable to connect to JTAG UART because another application
nios2-terminal: is using it (or is using something else which clashes). Please close
nios2-terminal: the other application and try again.
$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster ", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
+ Stopped nios2-terminal
$ ^C
