20 years agoHow to get current heap pointer?
My project need to read current heap pointer, but I don't know how to implement it. In NiosII IDE, Variables Window, you can add a global variables for watching, and I find heap_end which is...
20 years ago --- Quote Start --- originally posted by david_cai@Aug 11 2006, 07:01 AM could you kindly tell me how can you find the answer?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17538)
--- quote end ---
--- Quote End --- Hmm, let's see ... 1. I created a sample project to see if I would get the same problem. 2. I looked in the objdump file if the symbol was indeed defined (it was) (If you want to know anything about an elf (file format used by gcc) executable/object file look at it with objdump) 3. I googled 'heap_end'. a promising hit 'told' me that heap_end was defined by the c-library. 4. I searched the c-lib sources in my local filesystem for 'heap_end' (I didn't use the explorer for that. I did use a program that searches the content of all files for 'heap_end'). 5. Voilá, file found => static definition. 6. I know that static symbols are visible only in the current file. You know, experience is difficult to explain... Wolfgang
