12 years agoHow to get an oooold Nios II IDE?
Hi, I've got a problem: Our company is doing alot with Altera stuff. Currently we develop a Cyclone V SoC Design for some kind of measurement system. We use Cyclone III very succesfully a...
12 years ago --- Quote Start --- In the script there is a .sof file referenced. Additionally, if I check the JTAG chain of our hardware, I only see the Cyclone I FPGA, but no flash. --- Quote End --- Flash will not show up in the JTAG chain. Most likely the Cyclone I is configured from EPCS. Did you look at the schematic for the board? --- Quote Start --- So I already thought to myself that the FPGA will be configured as some kind of flash programmer by the nios2-flash-programmer.exe. Then, the flash image will be programmed into the flash device by via the FPGA. This sound pretty much like I program the Cyclone III config device with my .jic file. --- Quote End --- Yes, exactly. If you look at the schematic and see an EPCS flash, then you can just program it using a .jic. Once you confirm that works, you can use whatever file the command-line tool expects. For example, I believe you can save the JTAG chain from the programmer GUI, and then use that from the command-line. Cheers, Dave
