19 years agoHow to get a gdb server running?
What's the simplest way to get a gdb server running using a USB Blaster for the target connection to a NIOS2 target? I'd vastly prefer Linux, since that's where I'm doing my dev...
19 years ago --- Quote Start --- originally posted by slacker@Oct 28 2006, 05:53 PM unfortunately, you're going to have to get quartus ii, or, at a minimum the quartus ii programmer.... all of the jtag stuff (including the gdb server shipped with the nios ii eds) use the code in qii. --- Quote End --- I guess one of my colleagues was right the other day when he said that Altera sure goes to a lot of effort to make it difficult and expensive to use their parts. <div class='quotetop'>QUOTE </div> --- Quote Start --- You could take a look at the last section in the Flash Programmer User's Guide about "stand alone" installation, as the flash programmer has the same, basic requirements as the GDB server.[/b] --- Quote End --- Thanks. I'll take a look at it.
