19 years agoHow to get a gdb server running?
What's the simplest way to get a gdb server running using a USB Blaster for the target connection to a NIOS2 target? I'd vastly prefer Linux, since that's where I'm doing my dev...
19 years agoUnfortunately, you're going to have to get Quartus II, or, at a minimum the Quartus II programmer.... All of the JTAG stuff (including the GDB server shipped with the Nios II EDS) use the code in QII.
You could take a look at the last section in the Flash Programmer User's Guide about "stand alone" installation, as the flash programmer has the same, basic requirements as the GDB server. Here's a quick look at what the gdb-server-wrapped executable requires on Linux:ldd `which nios2-gdb-server-wrapped`
linux-gate.so.1 => (0xffffe000)
libdl.so.2 => /lib32/libdl.so.2 (0xf7f38000)
libjtag_client.so => not found
libstdc++.so.5 => /emul/linux/x86/usr/lib/libstdc++.so.5 (0xf7e85000)
libm.so.6 => /lib32/libm.so.6 (0xf7e60000)
libgcc_s.so.1 => /lib32/libgcc_s.so.1 (0xf7e55000)
libc.so.6 => /lib32/libc.so.6 (0xf7d2f000)
libpthread.so.0 => /lib32/libpthread.so.0 (0xf7d18000)
/lib/ld-linux.so.2 (0xf7f8e000) The "libjtag_client.so" is what's provided by (at least) the stand alone QII programmer. As to what's available freely (on Linux), I don't know.... Cheers and good luck! - slacker
