21 years agoHow to generate sof of FPGA when using ROM?
My design has embeded a ROM of 4096bytes inside FPGA. How could I modify the content of ROM in sof file without recompiling the whole design?
21 years agoQuartus "smart compile" should help you.
This feature skips compilation stages which aren't needed - in this case it can skip synthesis and routing and just rerun the final stages of compilation. You can turn it on from the Quartus Assignments/Settings menu - choose "Compilation tools settings" in the tree and then tick the box. You may find that the "incremental compile" option is useful.
