21 years agohow to ftp file to board
I setup linux on the board. And my PC can access "ftp" and "http" directory in the flash of the board, howerver they can be only read. How to access the compact flash of the board using ftp service? ...
21 years ago --- Quote Start --- originally posted by tlaskowski@Oct 20 2004, 09:31 AM hi,
fyi, i have used leechftp sucessfully with the board, without having to use the command line ftp.
you have to make sure you log in as a 'root' user in order to see all the directories.
-thomas --- Quote End --- Hi, Yes, I tried to log in using root. But I don't know the password for root. I only know the usr:nios and password: uClinux. Otherwise, I can transfer the file using ftp by IE directly. Could you tell me how to log in with root? thanks!
