20 years agoHow to freeze NIOS2 during sensitive measurement?
Hi community, we currently design a device where we use logic in a Cyclone for very accurate measuring. Beside the logic for measuring, there is a NIOS II in the same FPGA to processing the res...
20 years ago --- Quote Start --- originally posted by rsteiner+aug 30 2006, 10:28 pm--><div class='quotetop'>quote (rsteiner @ aug 30 2006, 10:28 pm)</div>
--- quote start ---
with what are you guys measuring? nios peripherals?[/b]
--- quote end ---
<!--quotebegin-kawk the measurement logic fires at 20 khz on its own. the nios accesses the peripheral regularly but only at 1 khz rate. --- Quote End --- It is, as you guessed, a custom peripheral with FIFO and several control registers. Kolja
