20 years agoHow to freeze NIOS2 during sensitive measurement?
Hi community, we currently design a device where we use logic in a Cyclone for very accurate measuring. Beside the logic for measuring, there is a NIOS II in the same FPGA to processing the res...
20 years agoHow about creating a custom hardware peripheral which asserts waitrequest during the measurement interval? The peripheral could contain a small counter which provides a fixed waitrequest interval, or it could base its waitrequest on an external signal which is active during the measurement (if that signal is available). You'd have the NiosII execute a non-cached data read or write to the peripheral during the measurement, and the niosII would stall until waitrequest is deasserted.
You didn't provide details on how the measurement is fired off, but if it's being controlled by a nios2-controlled peripheral, you might be able to build the waitrequest logic into the measurement peripheral itself. This seems more elegant. I'll assume that the measurement is triggered by one or more register writes to a peripheral - if so, simply change the hardware so that on the final register write, the peripheral asserts waitrequest until the measurement is complete.
