21 years agohow to erase my flash
i can't download my program to my flash! someone told me ,the flash needs to be erased using a program wrote by user! But how to write the program ? is there any other way to erase my flash!
thanks[B]5 Replies
Hi icesword,
> But how to write the program ? Use nios2-flash-programmer > is there any other way to erase my flash! If you want to completely erase your flash use the --erase option. Try: nios2-flash-programmer --help for a description of the options. Regards, --Scott - Altera_Forum
I am a beginner.I don't know where and how to use the instruction you said.whether you can give some details?
Hi icesword,
> I am a beginner. Welcome! :-) > I don't know where and how to use the instruction you said. > whether you can give some details? The documentation for flash programming can provide you with many details ... you should read this first. Then, if you have any questions you will be able to get more answers on this forum. Best Regards, --Scott - Altera_Forum
Ooops ... sorry, the document is:
Nios II Flash Programmer User Guide (ug_nios2_flash_programmer.pdf in the altera/kits/nios2/documentation directory). --Scott - Altera_Forum
thanks!
