20 years agoHow to erase flash completly?
I use “Reprogramming the Flash Memory" to restore factory_recovery.But it plays NOTES: Restoring flash has not changed the network settings for your kit. However, if the factory progr...
20 years agoIf you run the memtest example software template, there's a "hidden" feature which should allow you to erase your entire flash device. Just type 'e' at the main menu (I believe, though it could be in one of the sub-menus.
Cheers, - slacker
